2001 GMC Sierra Freeway Jumping
ACANCINO
I have a 2001 GMC Sierra with 90,000 miles and i have recently bought it. I noticed that it had airbags with schoks. I was driving on a freeway when sudenly the car started to jump a lot. I took out the air from the airbags and I droved again and nothing change. Do you think that if I take out the airbags would make the car jump less. Please help me because I am taking a trip to Colorado and I dont want to make a trip with this problem
Nov 15, 2007 at 2:34 PM
DENNYP
  • 1,824 POSTS
you should check the wheel balance first,and make sure your tires aren't worn.
Nov 16, 2007 at 11:42 AM
Suggested Repair
Check wheel balance first and inspect the tires for wear before considering removal of the air shocks.
Conversation Summary
The owner of a 2001 GMC Sierra with about 90,000 miles says the truck began jumping badly on the freeway. Deflating the air shocks did not change the ride, and the owner asked whether removing the airbags would reduce the bouncing before a trip. The expert advised checking wheel balance first and making sure the tires are not worn.
