4wd automatic trans failure
CHAUNCEBOMB
  • 5 POSTS
1983 GMC sierra, 120k mi, 350 v8- had trans rebuilt 2 yrs ago, has worked fine. I lost all gears while cruising about 40 mph on level road. This was accompanied by a gnarley sound of grinding/spinning noises. I put the vehicle in 4w lo, and it moves, so i drove home very slowly(it was about 20 degrees out and my wife was with me, and we were not dressed for a 5 mi. walk)is this an internal band/planetary problem? fluid was not leaking or low.
Mar 19, 2007 at 3:45 PM
CHAUNCEBOMB
  • 5 POSTS
you should probably just melt your truck into a single ingot of ferrous metal and sell it for the 18 dollars that would be worth. this would allow you to buy at least 3 packs of smokes that would get you through the sticker shock of a new truck that is comparable.
Mar 20, 2007 at 4:40 PM
