2008 GMC Sierra Pan removal
75,000 MILES • V8 • 4WD • AUTOMATIC
LHTBUILDER
I drained and removed all bolts to the tranny, but cannot remove it, do I need to remove the heat shield and the shift cable bracket?
May 31, 2010 at 5:06 PM
BLUELIGHTNIN6
  • 16,542 POSTS
remove the range selector cable bracket for clearance. shouldn't have to remove cable from the lever or bracket though. also have to remove the cat. converter. now remove bolts from the front and sides of pan only then loosen rear bolts 4 turns. lightly tap the pan with a rubber mallet to loosen it and allow fluid to drain. remove rest of bolts and pan should come down
May 31, 2010 at 5:42 PM
LHTBUILDER
I stripped the 40Torx screw that secyres the cable bracket, the screw is located above the tranny, very little clearance, how can I remove the stripped screw?
Jun 1, 2010 at 5:43 AM
BLUELIGHTNIN6
  • 16,542 POSTS
will have to use a screw extractor to remove the stripped screw. you use it like a normale screwdriver so you should have clearance.
Jun 1, 2010 at 6:02 AM
LHTBUILDER
the cat convertera are welded to the exhaust pipes, do I need to remove both exhaust pipes or do I cut off the cat. converters and weld them back on later?
Jun 1, 2010 at 6:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
remove the entire pipes
Jun 1, 2010 at 6:34 AM
