2007 GMC Sierra Reset Tire Monitor Pressure System
2007 GMC SIERRA
19,000 MILES • V8 • 2WD • AUTOMATIC
LAPSEB
I just had the dealer put on 2 new front tires and alignment done. My Tire pressure monitor now needs to be reset to read the tire pressure. How do I do this?
Sep 13, 2008 at 4:18 AM
BRIAN 1
  • 1,030 POSTS
I'm suprised the dealer didn't reset the tpm?you can follow this to reset it. this info should be in your manual.Ignition ON, initiate the TPM Learn Mode using one of the following procedures:
• On vehicles equipped with keyless entry, simultaneously press the keyless entry transmitters lock and unlock buttons until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
• On vehicles not equipped with keyless entry, press and release the driver information center (DIC) INFO button until the TIRE LEARN message appears on the DIC display. Press and hold the SET/RESET button until a double horn chirp sounds indicating the Learn Mode has been enabled. The left front turn signal will also be illuminated.
Starting with the left front tire, learn the tire pressure using one of the following methods:
• Hold the antenna of the J-46079 aimed upward against the tire sidewall close to the wheel rim at the valve stem location. Press and release the activate button and wait for a horn chirp. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
Caution: Over inflating tires may cause personal injury or damage to the tires and wheels. When increasing tire pressure do not exceed the maximum inflation pressure as noted on the tire sidewall.
• Increase/decrease the tire pressure for 8-10 seconds then wait for a horn chirp. The horn chirp may occur before or up to 30 seconds after the 8-10 second pressure increase/decrease time period has been reached. Once the horn chirp has sounded, the sensor information is learned and the turn signal in the next location to be learned will illuminate.
After the horn chirp has sounded and the right front turn signal is illuminated, repeat step 2 for the remaining 3 sensors in the following order:
3.1. Right front
3.2. Right rear
3.3. Left rear
When the left rear sensor has been learned and a double horn chirp has sounded, the learn process is complete and the RCDLR exits the learn mode.
Ignition OFF, adjust all tires to the recommended pressures.
Sep 13, 2008 at 9:33 AM
