2007 GMC Sierra Overheating Damage
38,000 MILES • V8 • 4WD • AUTOMATIC
GERMJOE2000
What temperature will damage engine parts. Is there a way to determine if there is damage to engine parts after overheating?
Apr 3, 2010 at 2:51 PM
  • 110,251 POSTS
As far as the temp, it really deals with what conditions the engine is under. Will the engine still start?
Apr 3, 2010 at 4:14 PM
GERMJOE2000
Yes, The engine will start....I was just curious to know what temp the cylinder heads would start to warp at. I hadn't had a chance to take the snowplow off and there was a record high temperature and my engine over heated.
Apr 4, 2010 at 12:10 PM
  • 110,251 POSTS
THey shouldn't warp until you are over 150+ degrees. Even at that point, there is a good chance a head gasket will go but the heads will be fine. If they are warped, you can have them machined.
Apr 4, 2010 at 4:13 PM
  • 110,251 POSTS
THey shouldn't warp until you are over 250+ degrees. Even at that point, there is a good chance a head gasket will go but the heads will be fine. If they are warped, you can have them machined.
