2006 GMC Sierra Transmission will not go into drive
48,000 MILES • 6 CYL • 2WD • AUTOMATIC
JGPEAKE
Truck can be driven in other setting, but will not go into drive
Jun 20, 2008 at 2:38 PM
AIRSOFTSOLDRECN9
  • 348 POSTS
The shifting mechanism inside of the transmission may not actuate for drive (this mechanism has different settings for single speed (1) and two speed (2)). The car needs to be looked at by a transmission specialist; however, you can check for proper fluid level in park and the engine running at normal operating temperature.
Jun 20, 2008 at 2:55 PM
