2005 GMC Sierra speedometer
2005 GMC SIERRA
52,000 MILES • 6 CYL • 2WD • AUTOMATIC
MSNELSON
Needle on the speedometer does not return to '0". When driven , readings vary from 0- 120, Is this a major labor job ? is there an easy fix? Mechanical or is there a sending unit I can replace?
Nov 25, 2008 at 7:48 AM
ED_12ROD
  • 12 POSTS
Your best bet is replacing your gauge cluster thats the simplest and cheapest fix. I have also experienced that problem the dealership is charging me 1k to fixing it. It comes out better off going to a junkyard
Aug 7, 2009 at 7:32 AM
