2005 GMC Sierra oil pressure
2005 GMC SIERRA
112,000 MILES • V8 • 2WD • AUTOMATIC
WALTER44
  • 7 POSTS
-When the key is in the on position (engine not running) it shows that I have oil pressure. I'm sure its the oil pressure sending unit I am unable to locate the oil pressure sending unit.
-Interrier smells like? Especially when you turn on the air condition.
--it appears that something is missing on the front hub of the water pump pulley. I have electric cooling fan BUT you see the belt pulley and the shaft. The shaft is threaded. What is keeping the pulley on the spindle??
Oct 13, 2009 at 3:44 PM
  • 110,244 POSTS
The oil pressure sending unit is located on the top rear of the engine block. Here is a picture.
https://images.2carpros.com/forum/automotive_pictures/249084_oil_1.jpg
As far as the other question, is it possible for you to take a picture of it and upload it for me to see?
Oct 13, 2009 at 3:56 PM
WALTER44
  • 7 POSTS
I have sent you a new list of questions along with pictures still have recieved no reply..
https://images.2carpros.com/forum/automotive_pictures/421369_000002_1.jpg
https://images.2carpros.com/forum/automotive_pictures/421369_000001_3.jpg
https://images.2carpros.com/forum/automotive_pictures/421369_000001_2.jpg
I need your help.. Please..
Oct 16, 2009 at 10:02 AM
  • 110,244 POSTS
Sorry, I just got the pictures now. As far as I can tell, there should be a fan clutch bolted on there with the fan attached to the clutch. Here is a picture of a fan clutch. It would screw onto the threaded item and then the fan attaches to the clutch.
https://images.2carpros.com/forum/automotive_pictures/249084_fan_1.jpg
Oct 16, 2009 at 4:42 PM
WALTER44
  • 7 POSTS
I have a question.. Would my truck still have a fan clutch even tho from the facory it came with 2 electric cooling fans?
Oct 18, 2009 at 7:48 AM
  • 110,244 POSTS
It could. I assume that it should because there is a listing for one when I looked up the part.
Oct 18, 2009 at 8:24 AM
WALTER44
  • 7 POSTS
As you see in the picture, currently what is really keeping on that fan pulley?? Is it a press fit? If the surpentine belt breaks will it come flying off and go through the rad???
My other question how do I get rid of the smell every time the heater is turned on. Smell is there weather the heat is on or the air condition.. I've looked into it and there is no filter..
Confused!
Oct 19, 2009 at 5:04 AM
  • 110,244 POSTS
It is most likely threaded in the center. As far as the smell, is it a coolant smell?
Oct 19, 2009 at 6:24 AM
WALTER44
  • 7 POSTS
You know as for the smell goes. No not like anti-freeze.
It has a real weird smell. A neighbor was walking by (he's kinda noisy) How can I get rid of the smell.
I had the interior professionally cleaned. I also had the seats steam cleaned. About 3-5 days later the smell is back.
Oct 19, 2009 at 9:57 AM
  • 110,244 POSTS
That is a good one. I have no idea and never had this problem before. I will ask the site owner if he has any suggestions.
Oct 20, 2009 at 12:23 AM
