2005 GMC Sierra NOISE IN STEERING
2005 GMC SIERRA
71,000 MILES • V8 • 2WD • AUTOMATIC
MICKEYTALK
THERE IS NOISE IN FRONT OF TRUCK LIKE A RUBBING SOUND. I CAN FEEL A ROUGH NESS IN THE STEERING. I HAD THE FRONT END LOOKED AT AND THAY SAID IT WAS JUST PLAY IN THE STEERING. IT DOSE MAKE A NOTICEABLE NOISE AND I CAN FEEL IT IN THE STEERING WHEEL
Jan 14, 2010 at 5:18 AM
  • 110,244 POSTS
Does the sound change when making turns? Can you describe the noise? Have the brakes been checked?
Jan 15, 2010 at 4:30 AM
MICKEYTALK
[quote:7dc619bae0="Jacobandnickolas"]Does the sound change when making turns? Can you describe the noise? Have the brakes been checked?
Joe[/quote:7dc619bae0] THE SOUND IS LIKE A RUBBING SOUND,THE SOUND DOSENT CHANGE WHEN TURNING BUT IT CONTINUES TO MAKE THE NOISE IN TURNS. I HAVE NOT HAD THE BREAKS CHECKED. OUR TOWN DOSE NOT HAVE THE BEST STREETS, WHEN TURNING FROM STREET TO STREET THERE ARE DIPS IN THE STREET. THE SOUND IS VERY NOTICABLE AT THESE TIMES BUT ALSO WHEN JUST DRIVING STRAIGHT DOWN THE ROAD
Jan 18, 2010 at 6:40 AM
  • 110,244 POSTS
I would recommend having the wheel bearing checked. Also, make sure the brakes are in good condition and a sensor isn't touching.
Jan 18, 2010 at 8:16 AM
MICKEYTALK
THANKS FOR ALL OF YOUR HELP
IT TURNED OUT TO BE MY STEERING COLUMN
DEALER REPLACED AND ALL IS WELL
Feb 5, 2010 at 3:15 AM
  • 110,244 POSTS
Wow, I wouldn't have gotten that one without being there. Regardless, I'm glad you found the problem and it is fixed.
Thanks for using 2carpros.com.
Feb 5, 2010 at 5:23 AM
