fuel filter
50,000 MILES • V8 • 2WD • AUTOMATIC
HANK FOWLER
where is fuel filter located?
Jan 22, 2008 at 10:10 AM
DENNYP
  • 1,824 POSTS
The fuel filter should be integral to the fuel pump assembly.
Jan 31, 2008 at 2:05 PM
RACHELCALLIOU
We recently replaced the fuel filter on our truck. The problem was our truck kept dying while driving it, and sometimes wouldn't start. It seems to be fixed but is still occasionally stalling while driving. We found out that they did not change t he fuel filter as well. Could this be causing the problem? If so how do we change it? =) Also the truck is a deisel.
Apr 16, 2019 at 11:43 AM (Merged)
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated I'm guessing you had the pump changed and not the filter ?? your post is not realy clear ?? there is a filter on the tank and a secondry filter !! the filter could be your problem .. change the secondry filter mounted on the firewall/air cleaner .. also add a good fuel cleaner to the tank to clean the lines and injector's ! A mechanical pump is mounted on the right side of engine block. Camshaft eccentric drives pump. Pump pulls fuel from the fuel tank through a primary filter. The fuel is then pumped through a secondary filter, mounted on firewall (pickups) or rear of air cleaner (vans), and to the injection pump. FUEL MANAGER/FILTER ELEMENT Removal Fuel filter is mounted on rear of intake manifold, under air cleaner. Remove fuel tank cap to release pressure or vacuum in tank. Remove filter element nut. Remove filter element by lifting straight out of filter housing. See Fig. 8. It is not necessary to drain fuel from filter housing when changing filter element. Fig. 8: Diesel Fuel Manager/Filter Components
https://images.2carpros.com/forum/automotive_pictures/266999_gmc_2.jpg
hope this helps
https://images.2carpros.com/forum/automotive_pictures/266999_AAA2_866.png
UNCLEBILLC
What is the best way to replace the Diesel Fuel Filter? I tried putting the new filter in from under the truck, prior to removing the existing filter and the header was in the way. I tried putting the new filter in from the topside of the engine, and there too there were too many "things" in the way. In both cases the filter would not fit. It looks like if you remove the inner wheel well the filter can be removed and installed that way. That would be a lot of extra work. Do you have any suggestions or experience with this issue?
BRIAN 1
  • 1,030 POSTS
I remove the inner wheel well,it's easier. here is how. Drain the fuel from the fuel filter. Refer to Water-in-Fuel Draining .
Disconnect the following electrical connectors:
• Water-in-fuel sensor (1)
• Fuel heater (2)
Reposition the fuel hose clamps.
Remove the fuel hoses from the fuel filter/heater element housing.
Disconnect the electrical and vacuum lines from the following:
• The exhaust gas recirculation (EGR) valve vent solenoid
• The EGR valve vacuum sensor
• The EGR valve solenoid
Remove the fuel filter bracket bolts.
Remove the fuel filter/heater element housing.
Remove the fuel filter bracket from the fuel filter/heater element housing.
Remove the fuel filter from the fuel filter/heater element housing.
Inspect the fuel filter, replace if necessary.
Installation Procedure
Install the fuel filter to the fuel filter/heater element housing.
Notice: Use the correct fastener in the correct location. Replacement fasteners must be the correct part number for that application. Fasteners requiring replacement or fasteners requiring the use of thread locking compound or sealant are identified in the service procedure. Do not use paints, lubricants, or corrosion inhibitors on fasteners or fastener joint surfaces unless specified. These coatings affect fastener torque and joint clamping force and may damage the fastener. Use the correct tightening sequence and specifications when installing fasteners in order to avoid damage to parts and systems.
Install the fuel filter bracket to the fuel filter/heater element housing.
Tighten
Tighten the bolts to 20 N·m (15 lb ft).
Install the fuel filter bracket bolts.
Tighten
Connect the electrical and vacuum to the following:
• The EGR valve vent solenoid
Connect the fuel hoses to the fuel filter/heater element housing.
Prime the fuel system.
Connect the following electrical connectors:
• Fuel heater (2)
Connect the negative battery cable. Refer to Battery Negative Cable Disconnection and Connection .
Start the engine and inspect for fuel leaks.
when your done,there is a bleeder screw next to the primer open it and crank the engine until all the air is out,then close it and pump the primer about 40 times or until it gets stif,then it should start.
