2005 GMC Sierra Engine Noise under load and after starting
70,000 MILES • V8 • 2WD • AUTOMATIC
AMRAAM35
  • 39 POSTS
I have a 2WD GMC Sierra pickup with the 5.3L V8. Recently, it makes a grinding like noise when i start it up and is in park. It goes away shortly after i start it up but shows up again when the engine is accelerating at any speed.
It does not throw an engine code, and the alternator is giving 14 volts, the power steering appears to be working fine (cant feel any resistance) and my brakes feel fine. My wheel bearings and ball joints are ok. I just had to replace my front passenger side wheel hub and bearing because it blew out. Does not seem related because the front suspension is isolated from the engine. No visible dents or damage to the engine bottom, but it is very muddy, i had driven off-road with it.
Mar 14, 2010 at 6:55 AM
AMRAAM35
  • 39 POSTS
No engine codes, the engine mounts appear in good shape. I took off both accessory belts and that did not change the problem. my harmonic balancer pully (pulley powered by the engine) looks like it is slightly offcenter, (est. 1-2 mm wobble).
Mar 14, 2010 at 8:07 AM
  • 110,246 POSTS
When you hear the noise, does it change with RPM's?
Let me know. Also, could the sound be coming from the rear of the engine?
Mar 15, 2010 at 3:57 PM
AMRAAM35
  • 39 POSTS
Turned out a had a big rock lodged between my exhaust and frame near my transmission. Could not see it until i got it up on a lift. Runs great now that its gone. Thanks for the help.
Mar 16, 2010 at 4:58 AM
  • 110,246 POSTS
That is good. An easy fix.
Let us know if you have questions in the future.
Mar 16, 2010 at 5:22 AM
