2005 GMC Sierra driver side heated seat
70,000 MILES • V8 • 4WD • AUTOMATIC
LKLIMA
I have an 2005 GMC serria pickup, I had the driverside mirror (remote, heated and blinker) replaced at the dealer and after that the heated seat on the drivers side now does not work. The light on the switch will not go on.I thought that maybe the serviceman forgot to hook up the wire, but the dealer said that there is power to the switch and out of the switch. The heated seats worked ok the day before I took it in for the mirror replacement.. Any suggestions as to what is wrong??? The passenger side heated seat does work...
Oct 26, 2010 at 5:59 AM
GMTECH
  • 537 POSTS
Double check to make sure that the connector is hooked up to the switch. It has to be disconnected to remove the door pad when replacing mirror. It is possible that the switch is defective but it seems very coincidental that it doesn't work after being serviced.
Nov 3, 2010 at 1:18 PM
