2004 GMC Sierra High Oil Pressure
TREBOR111
  • 2004 GMC SIERRA
  • V8
  • 99,000 MILES
Does any body know why my 2004 Seirra oil pressure gauge goes really high sometimes I drive it. It goes as high as off the numbers on the gauge. Do I need a new oil pressure sensor. Thanks
Saturday, March 14th, 2009 AT 4:14 PM
Any type of weird noises coming from inside the engine
Could be the oil pressure switch-Check the oil pressure with a mechanical gauge and if normal replace the oil pressure switch abnormal the oil pump pressure relief valve might not be opening or an engine bearings problem.
Saturday, March 14th, 2009 AT 5:20 PM
ED_12ROD
  • 12 POSTS
Do you give the truck high revs the gauge move with the revs when accelerating.
Friday, August 7th, 2009 AT 10:13 AM
