2004 GMC Sierra
2004 GMC SIERRA
AR1825
Air Conditioning problem
2004 GMC Sierra V8 Two Wheel Drive Automatic
my truck has been throwing out warm/hot air thru the driver side vents, while throwing out cool air thru the passenger side vents what is causing this?
Sep 28, 2009 at 7:31 PM
BMRFIXIT
  • 19,053 POSTS
Check A/C system if full and have enough pressure on low and high sides
if the system function is all in order
I would suspect blend door actuator
I would check and make sure if 134A low in system 1st
Sep 28, 2009 at 8:01 PM
