2004 GMC Sierra
EXTENDEDCAB
2004 GMC Sierra V8 Four Wheel Drive Automatic
my engine light is on and it tells me to tighten my fuel cover, so I put on a new cover and it is still coming on
May 14, 2009 at 12:45 PM
DR LOOT
  • 2,311 POSTS
I was hoping I would never come across this problem again, okay listen to me, have you replaced your fuel cap yet? the reason I ask is because the O-ring starts to crack and does not seal the fuel tank, if you have filled up your vehicle without shutting it off it will also set this code, but the most important question is if you do not let your vehicle get below a half tank (which is smart) and then you let it get below a half a tank, especialy on a hot day, the E-vap valve fails to open and allow the fumes from the fuel tank to escape it will also set a code, the only way to fix this is with a scanner and manually open the valve several times until it gets unstuck. sorry, if I can be of any more assistance let me know you can contact me on yahoo anytime.
May 20, 2009 at 2:40 PM
