2003 GMC Sierra Dim interior lights
85,000 MILES • V8 • 4WD • AUTOMATIC
DITCH
Hello there I have a problem with my dash,door and reading lights it seem that thay are only running at half the voltage thay need.
Jan 12, 2009 at 10:27 AM
KEVIN12881
  • 336 POSTS
Do you not have a dial to turn them up or down? Has that dial been hit hard, it may need replaced, or the wire may have come loose.
Jan 12, 2009 at 10:45 AM
DITCH
my instrument has the right brightness could it be a bad ground
Jan 12, 2009 at 1:38 PM
KEVIN12881
  • 336 POSTS
could, but i think a bad ground would cause it to flicker.. Electric problems in cars are always tricky, and not my experteese. (neither is spelling)
Jan 13, 2009 at 8:41 AM
