2003 GMC Sierra check engine light, reduced engine power
176,000 MILES • V8 • 2WD • AUTOMATIC
JMGUTI
I had a computer diagnostics check on the engine and received the following information:
Definition: TAC module throttle actuator position performance.
Explanation: The ECM has detected an out of range condition between the predicted and actual throttle position.
Probable causes:
1. Poor connection at the TAC module
2. Failed TAC module
3. Check TPP or TPS sensors
4. Binding or bent throttle plate-failed throttle body.
Can you provide some help as to what exactly I need to be checking for? And where can I find schematics for the above problem?
Your help is greatly appreciated!
Oct 27, 2008 at 4:57 AM
DENNYP
  • 1,824 POSTS
First, clean the carbon from the throttle body. Then, clear the trouble code and see if it comes back. If it does, let me know what the code number is.
Oct 28, 2008 at 4:47 AM
