A/C blowing fuses.
2003 GMC SIERRA
JNOROPALLO
I have had several mechanics tell me different things on why my a/c keeps blowing fuses. When the truck is in park and idling, it works ok. Sometimes, when I put it in drive, it blows the fuse. Also, sometimes it doesn't blow the fuse when I put it in drive, but when I drive about 1/4 mile, it blows. I tried to put a larger fuse in (20 instead of 10 amp) it still blows. Some mechanics say its the compressor (very expensive) or the a/c clutch, or a wiring short. I don't think the compressor would be the problem because I can sit and idle for hours and it works fine. I also checked through all the wiring and its seems fine. What do you think it may be?
Jun 14, 2008 at 3:55 PM
JAWARD
I have a 2003 Chevy Silverado 1500 4.8L. I have the exact same problem I took it to the dealer and they replaced the AC compressor for $760.00 all fixed. They said the clutch coil has shorted out.
I found this guide I should have done it myself.
https://www.2carpros.com/articles/replace-air-conditioner-compressor
I love this site.
Jul 14, 2019 at 12:25 PM
