I have a 2003 GMC Sierra 8.1L v8 is has the padlock symbol coming on steady bright sometimes and sometimes not. The main problem is that the truck will crank but not fire up sometimes only after it cranks for a long time like 20-30 seconds then it will start and alot of black smoke comes out. Once started it runs ok. The padlock/half car light sometimes illuminates. I think it is a passlock problem and would like to disable it without going to the dealer and get the run around. Can I just replace some parts simply? Maybe the ignition switch? i also have read alot about the problem but cannot find the actual cause/defect of the problem. what is the manufacture's defect as to why this is happening?
Apr 16, 2010 at 9:04 AM
