2002 GMC Sierra Throttle kills engine
112,000 MILES • V8 • 4WD • AUTOMATIC
LVPENNIMAN
My truck started missing while driving home, eventually not responding to the accelerator and finally turning off as I pulled into a parking lot. Will occasionally crank, but will only idle for about 30 seconds before dying. Any increase in throttle kills the engine. I have changed the fuel filter, plugs & wires, throttle position sensor, cleaned throttle body, changed the MAF sensor. OBD codes P0102, P0332, P0452 are what came up on my code reader.
Aug 20, 2010 at 1:06 PM
WRENCHTECH
  • 20,760 POSTS
The first thing you want to check is the fuel pressure. This is a high pressure system that won't even run if the pressure drops below 55PSI.
Fuel pumps are the #1 cause of "no starts" in that vehicle.
Aug 20, 2010 at 1:49 PM
