1989 GMC Sierra 89 Chevy TBI
GPYOUNKER
  • 1989 GMC SIERRA
Engine Performance problem
1989 GMC Sierra V8 Four Wheel Drive Automatic 80;000 miles
When you first start and run the engine it runs fine for about 10 min. Then it goes haywire dumping to much gas into the TBI There is a loud air sound comming out of TBI exhaust gas burnes your eyes very rich, could it be fuel pressure Regulator Or what els can I check.
Thank you Glen
Wednesday, June 11th, 2008 AT 12:19 PM
BMRFIXIT
  • 19,053 POSTS
Hi Glen
it is very possible that the fuel pressure is bad and you need to have it checked
I would also recommend checking the EGR valve and its operation
check and or replace MAP sensor and its vacuum line
check for codes if possible
Wednesday, June 11th, 2008 AT 9:16 PM
