2002 GMC Sierra power steering out
2002 GMC SIERRA
52,000 MILES • V8 • 4WD • AUTOMATIC
JACKIEGREEN
Low miles on my truck and never any issues, yet yester drove it 45 miles, parked, and as I was parking it was if the power streering just stopped. Can not turn wheels, not locked, will move a inch or two if you put all your weight into. Fluid, good, no leaks on ground and no warnings steering was having any issues... had to have it towed home. Could the steering box just go out like that? Or what can I check? Is there a fuse in the side panel? Baffled.
Thanks...
jackie
Mar 7, 2010 at 1:21 AM
  • 110,244 POSTS
Jackie:
Doesn't it turn at all? Did you check to see if the steering pump is turning?
Mar 16, 2010 at 1:38 AM
