2002 GMC Sierra PLASTIC WASHER LINE
2002 GMC SIERRA
40,100 MILES • V8 • 4WD • AUTOMATIC
LARS1040
THIS MAY BE AN EASY QUESTION. I NEED TO REPLACE THE SUPPLY LINE FOR THE WINDOW WASHER. THE LINE DISAPPEARS UNDER THE BATTERY AND I CAN NOT SEE HOW IF FITS INTO THE RESERVOIR. IS IT PART OF THE RESERVOIR ? DO I REPLACE LINE AND RESERVOIR OR JUST LINE. THE LINE THEN GOES UP TO THE WIPERS AND I'M NOT SURE HOW THAT CONNECTION IS MADE.
Jan 11, 2010 at 5:54 PM
  • 110,194 POSTS
Actually, it is easy. The rubber hose connects to the windshield washer pump located at the bottom at the bottom of the resivour. It will fit snuggly over a nipple on the pump. It just pulls off and pushes on.
Jan 15, 2010 at 12:55 PM
