Was diagnosed at Autozone with Transmission Pressure Switch issue. Took to Dealer, had Tran. Pressure Manifold Switch replaced and front U-Joint. One week later and 269 added miles, transmission shifted harder than normal, with fluid getting hot and gauge showing hot. Stopped it completely, let set for 5 hours and went back for it. Drove another 5 miles to home and parked it. I drove the truck for the past week and noticed some rougher than normal shifting. I don't think this was anything dealer related, thinking maybe the torque converter is going out. This is the Allison transmission and 6.6 turbo diesel 2500HD. Wanted to elaborate on the correct model. This was the first time that it has ever overheated. Thank you for your comments. While driving it home I had to stop at stop signs at every cross street for appx. 1/2 mile. Was traveling about 40 mph when the gauges notified me of the heat problem. Haven't noticed any leaking and the tran. fluid is full on dipstick.
Jul 10, 2010 at 2:37 PM
