2002 GMC Sierra Fuel Pump Problem
19,200 MILES • V8 • 4WD • AUTOMATIC
MRBLACKWELL
  • 6 POSTS
I CHANGED THE FUEL PUMP IN MY SON'S TRUCK BECAUSE IT WOULDN'T RUN. BEFORE I DID THIS, I CHECKED THE FUEL PUMP RELAY & ECM-B FUSE.
THEY WERE GOOD.
THE REASON I SUSPECTED FUEL PUMP IS BECAUSE I COULDN'T HEAR THE FUEL PUMP CYCLE WHEN WE WERE TRYING TO START THE TRUCK
AFTER CHANGING THE FUEL PUMP, THE TRUCK STILL WON'T RUN. I WENT BACK & CHECKED THE RELAY & ECM-B FUSE AGAIN.
THAT'S WHEN I DISCOVERED THAT THERE IS NO POWER TO THE FUEL PUMP RELAY.
THE FUEL PUMP WILL CYCLE FOR A VERY SHORT TIME, (LESS THAN A SECOND) WHEN THE IGNITION IS FIRST TURNED ON.
THE OIL PAN GASKET WAS REPLACED ABOUT A WEEK PRIOR TO HAVING THIS PROBLEM, SO I'M WONDERING IF THE OIL LEVEL SENSOR COULD HAVE BEEN DAMAGED DURING THE PROCESS.
(JUST A GUESS) AFTER THE OIL PAN GASKET WAS REPLACED, WE DROVE THE TRUCK HOME & IT WAS NOT DRIVEN AGAIN UNTIL WE TRIED TO START IT & DISCOVERED THIS PROBLEM.
THE TRUCK IS A 2500HD WITH THE 8.1 ENGINE.
Jul 27, 2010 at 12:31 PM
DOCFIXIT
  • 18,828 POSTS
Hi
ECMB 1 does power up relay are you using a volt meter to test voltage at fuse and across? Power origantes at small red wire off battery to fuse box. Make voltage readings at fuse box
Let me know
Thanks for donate
Jul 28, 2010 at 7:08 AM
MRBLACKWELL
  • 6 POSTS
I used a test light because I didn't have a volt meter with me at the time.
There is power on both sides of the ECMB-1 fuse,but I don't know what the voltage is.
Jul 28, 2010 at 7:15 AM
DOCFIXIT
  • 18,828 POSTS
Need meter tests light will light on little voltage and AMPS.
If fuse is powered then must be fault in wiring from fuse to relay
Jul 28, 2010 at 7:24 AM
MRBLACKWELL
  • 6 POSTS
Ok. I will check when I get home & see what the voltage is.
Jul 28, 2010 at 7:52 AM
MRBLACKWELL
  • 6 POSTS
Haven't had a chance to check with volt meter yeat, but just out of curiosity, where is the pcm located ?
Jul 30, 2010 at 8:02 AM
DOCFIXIT
  • 18,828 POSTS
Underhood
https://images.2carpros.com/forum/automotive_pictures/198357_Graphic_539.jpg
Jul 31, 2010 at 2:28 AM
MRBLACKWELL
  • 6 POSTS
Ok, here's where I'm at. Ended up taking the truck to GMC dealer. They diagnosed as a bad PCM.
I purchased a used PCM & took it to them (I actually put it in while I was there) & they reprogrammed it later that day.
After doing that, it still won't run. The tech says that before the PCM swap, it had fuel pressure, but the PCM wasn't communicating.
After the PCM swap, it is communicating, but now has no fuel pressure.
I went to the dealer & talked to the tech & he wanted to spray some carb cleaner to see if it would run, I guess he was thinking that the aftermarket pump I had put in it had maybe gone bad.
Sprayed it with the carb cleaner & it still did not run.
Just out of curiosity, I looked at his TECH-2 & now there is no communication with the PCM again.
Aug 4, 2010 at 9:41 AM
DOCFIXIT
  • 18,828 POSTS
Know this will sound to simple but has the oil level switch in right side oil pan been checked? Story began with oil pan gasket tehn no start
Aug 5, 2010 at 3:43 AM
MRBLACKWELL
  • 6 POSTS
No, it hasn't been checked. I have the truck back from the dealer now. Didn't want to keep paying them to guess what was wrong.
What's the procedure for testing the oil level sensor ?
Aug 5, 2010 at 5:48 AM
