No power to the fuel pump
150,000 MILES • V8 • 2WD • AUTOMATIC
SACH38
put a new fuel in. No power going to it. I already checked all the fuses and relay.
Dec 12, 2007 at 9:50 AM
  • 75,988 POSTS
The computer energizes the fuel pump relay for 2 secs. Do you hear the pump for 2 secs when key is at On position. This is the time it should have power- You have to be at the fuel pump connector when key is at "on" position all you got is to 2 secs. Check it out and comeback with your findings meanwhile familiarize the schematic below.
https://images.2carpros.com/forum/automotive_pictures/12900_oil_sending_unit_and_fuel_pump_circuit_22.gif
Dec 12, 2007 at 12:06 PM
SC02GMC
Was there ever a finding if so can you post it please I’m in the same situation?
Sep 2, 2020 at 1:00 PM
  • 110,248 POSTS
I'm not sure if that was resolved. However, I will try to help. Have you checked if there is power to your fuel pump? Is your vehicle the same year make and model as what is listed?
Sep 2, 2020 at 1:19 PM
