2002 GMC Sierra
98,000 MILES • V8 • 4WD • AUTOMATIC
MDFBEAMER
I was wondering if anyone could help me I have a tick noise coming from my engine on start up. It goes away after about 30 seconds to a minute. Depending on how cold it is, not to mention it has been idling rough.
Also I have a knocking noise in the steering when I crank the steering wheel? Any help would be extremely appreciated.
Thanks,
Nov 28, 2008 at 6:50 PM
MASTERTECHTIM
  • 4,750 POSTS
well there are a few possibilities, most common on the tick noise is loose exhaust flanges from y pipe to manifold. the flanges rust and then there is not enough clamping force to hold y pipe to manifold and you will get a exhasut tick cold and it goes away when engine warms and metal expands. the noise in the steering column is usually cause by a bad intermediate shaft in the steering column, (known problem) the running rough could be as simple as needing a tune up
Nov 28, 2008 at 9:25 PM
MDFBEAMER
Thanks for you help! I appreciate it.....have a good one
Nov 29, 2008 at 2:28 PM
