2001 GMC Sierra Tailgate Problem
14,000 MILES • V8 • 2WD • AUTOMATIC
FERGMEISTER003BGF
The handle will not release the tailgate to let it open. It feels like one side is releasing and the other side is not.
Aug 16, 2010 at 5:39 AM
JDL
  • 16,098 POSTS
If this is a mechanical release, maybe you can get somebody to bang on that one side, while you work the handle. Try some spray lubricant on that one side and handle mechanism also. Maybe remove the handle mechanism, see if you can grab the linkage for that one side and pull?
Aug 16, 2010 at 5:57 AM
FERGMEISTER003BGF
Tried the banging deal. Tried shooting some WD-40 on the release by the left edge of the gate. Didn't knoe if removing the three bolts on the inside of the gate would do any good.
Aug 16, 2010 at 6:47 AM
JDL
  • 16,098 POSTS
I don't know if removing those bolts will help or not? Don't have any other ideas at the moment.
Aug 16, 2010 at 8:06 AM
WOODY RUDY
THE plastic clip that holds the linkage rod to the handle bezel is probaly broken. REMOVE the handle bezel by prying gently on the upper retainer tabs.THE left and right clips are different colors so they need to be put on the right side. IF the rod has fallen,you can make a hook out of a clothes hanger and retrive the rod.
Jan 5, 2011 at 5:31 PM
JDL
  • 16,098 POSTS
Did you ever get it going your way?
Mar 1, 2011 at 2:25 PM
