2001 GMC Sierra no power steering or brakes
170,000 MILES • V8 • 4WD • AUTOMATIC
MIKE V.
My truck is a 2001 GMC Sierra 2500 6.0 Liter. I was driving it and everything was fine went to park and all at once I lost my power steering and brakes. I had no leaks or nothing. So is the problem my power steering pump?
Jul 19, 2010 at 11:36 AM
  • 75,988 POSTS
Inspect and test the hydro boost pump, when this goes you lose both
Jul 19, 2010 at 11:39 AM
EDWARD.S
  • 166 POSTS
Hi, Check This First, Remove The Belt, See If You can Put Out The Power sterring Pulley From the pump,Just Try Pulling It Straight Out. If the Pulley Comes out Then you need a Power Sterring pump. A high Failure rate On these Trucks.
Hope This helps you,
Good luck
Edward S.
Jul 19, 2010 at 12:01 PM
