2001 GMC Sierra leaking tranmission fluid
2001 GMC SIERRA
135,000 MILES • 6 CYL • 4WD • AUTOMATIC
ALICIA03
In november 09 the u-joint in front end broke while on highway. When pulled over noticed transmission fluid pouring out. After getting drive shaft fixed and put new transfer case seal and all put together it is still leaking transmission fluid. Except it is leaking were transfer case and transmission meet now, and it is leaking at a rapid rate. Why is it doing this and how can it be fixed??
Mar 4, 2010 at 7:07 AM
2CARPRO JACK
  • 11,533 POSTS
It may have spit out he seal between the trans and transfer case.There are actually seals in both of them to keep fluid from going from one to the other.You will need to seperate the two to see what happened.
Mar 4, 2010 at 12:18 PM
