2001 GMC Sierra Exhaust Leak
60,000 MILES • V8 • 2WD • AUTOMATIC
FISHERMAN49
It sounds as if there is an exhaust leak when I first start the engine but then the noise quietens as the engine heats up. I read online that there has been a problem with the exhaust manifold bolts and wondered if this was the cause of the noise.
Feb 28, 2009 at 2:50 PM
  • 31,937 POSTS
HI there,
Remove any heat shields from the exhaust manifolds, check foe black carbon stains, start up and use a length of hose as a stethoscope and listen around all bolts and flanges and gaskets, if there is a leak this will pick it up easily, start here.
mark (mhpautos)
Feb 28, 2009 at 3:06 PM
