2001 GMC Sierra engine light on,
165,000 MILES • 6 CYL • 2WD • AUTOMATIC
CLASSIFIED
hi my question is this , my truck started to hesitate like low voltage or idling low then parked the vechile.came back to start it,had a difficult time but made it home around 2 blocks. next day tried to start it bt would not crank over. Thought it might be the altenator and was told this was not the cause. towed it from there to a mechanic and for 2 days has'nt figured it out yet. don't know to say but ay help wouldbe apreciated. thanks for your hellp, dan.
Jan 9, 2008 at 10:53 AM
SERVICE WRITER
  • 9,123 POSTS
Were there any codes stored in the computer? such as a po706. May be a nuetral saftey switch problem, codes would need to be cleared before it would start at that point.
Check to make sure the software is at it's most current version.
When it wouldn't start, were the lights bright?
Possible parasitic draw?
Jan 9, 2008 at 11:01 AM
