2001 GMC Sierra Door panel
121,000 MILES • V8 • 2WD • AUTOMATIC
COSBORNE
How do I remove the passenger side door panel to get at a defective radio speaker?
Oct 8, 2009 at 4:30 AM
SERVICE WRITER
  • 9,123 POSTS
Remove the door handle bezel.
Remove the window handle, if equipped.
Remove the power accessory switch panel.
Remove the trim panel upper extension.
Remove the trim panel screws.
Remove the courtesy light, if equipped.
Remove door panel screws.
Remove the trim panel from the door, carefully sliding the trim panel up to release the retainers from the door.
Remove the speaker wire.
Oct 8, 2009 at 4:53 AM
COSBORNE
How do I remove the following:
Regards-
Chuck Osborne
Oct 14, 2009 at 6:45 AM
SERVICE WRITER
  • 9,123 POSTS
https://images.2carpros.com/forum/automotive_pictures/30961_door_1.jpg
Open the front door. Release the upper extension by pulling outward in order to release the upper retainer clip. Remove the upper extension from the trim panel by lifting up and out.
https://images.2carpros.com/forum/automotive_pictures/30961_switch_1.jpg
Insert a flat-bladed tool into the slots on the power accessory switch panel in order to release the retainer clips. Remove the switch panel. Disconnect the electrical connectors from the switches. Remove the screws from the switches. Remove the power accessory switches from the switch panel.
Oct 14, 2009 at 8:26 AM
