2001 GMC Sierra Differential leaking out the seals
100,000 MILES • V8 • 4WD • AUTOMATIC
JIMEW65
I'm wondering how hard it is to change the seals out of my leaky GMC differential... also wondering if there is somewhere I can find instructions on how to do the job. Any ideas?[img:7309e1cd29]http://www.2carpros.com/forum/automotive_pictures/464215_truck2_2.jpg[/img:7309e1cd29]
Jan 14, 2010 at 1:37 PM
  • 110,248 POSTS
Which seal is leaking?
Jan 15, 2010 at 4:16 AM
JIMEW65
Axle seals... both sides (inner)
Jan 15, 2010 at 7:43 AM
  • 110,248 POSTS
This is a big job. I can give you the general idea, but recommend that you get a good repair manual that has step by step instructions. There is too much room for error via the net.
First, secure the rear of the vehicle off the ground. Remove the rear tires, drum, rear differential cover, and drain the gear lube. To remove the axles, there are retainers on each side of the differential that will need removed. Once the axles are out, you will have access to the seal. Remove the seal and replace. Make sure to place a thin film of gear lube on the seal before replacing the axle. Reverse the sequence to replace.
Jan 15, 2010 at 9:48 AM
