2001 GMC Sierra CODE PO101
77,565 MILES • V8 • 2WD • AUTOMATIC
CHRIS HENRY
HAS LOSS OF POWER AND ENGINE CODE PO101
Feb 23, 2009 at 7:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
P0101 Mass or Volume Air Flow Circuit Range/Performance Problem
Need to inspect your Mass Airflow (MAF) sensor. Suspect if may be faulty. This will usually cause poor power, poor idle and/or poor fuel mileage.
Thanks for using 2CarPros.com!
Feb 23, 2009 at 5:50 PM
CHRIS HENRY
thanks but the truck has a new m.a.f. sensor and map sensor
Feb 24, 2009 at 12:12 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Try unplugging it and see if it makes the vehicle run better. If it does then there is still a problem with it somewhere. Either wiring or something is dirty and not letting the sensor do its job correctly.
Feb 24, 2009 at 12:34 PM
