2001 GMC Sierra check engine light
165,000 MILES • V8 • 2WD • AUTOMATIC
SPARKY1974
i have a check engine light that comes on i checked the owners manual and it said to check the gas cap to see if it was tight it wasn;t i took the cap off and put the cap back on the light stayed on also i smelled gas fumes when i took off the cap. my question is how do i turn off the light
Jan 10, 2010 at 10:58 AM
BLUELIGHTNIN6
  • 16,542 POSTS
don't erase light until the trouble codes are retrieved. most auto part stores will retrieve the trouble codes for you free of charge. post codes you get and i will follow up .
Jan 11, 2010 at 9:53 AM
