2000 GMC Sierra Fuel Filter
113,000 MILES • V8 • 4WD • AUTOMATIC
XTMEYERX
I went to change my inline fuel filter and it is pretty rusty. I soaked both bolts in pb blaster and still no luck... my question is, iam i gonna have to replace the whole fuel line or is there a kit or somthing that can help me out. i would rather not just run it to a mechanic cause i wanna learn how to do things my self...Thanks Travis
Aug 15, 2010 at 8:18 AM
FACTORYJACK
  • 4,159 POSTS
Ideally, youare going to need to replace the line(s). Have you got to the point of rounding off the fittings, and are you using flare nut wrenches? If the fittings are not rounded, and you are not using flare nut type wrenches,you will be able to apply more force to more surface area of the fittings with their use. You may get them loose.
Aug 15, 2010 at 9:59 AM
