2000 GMC Sierra four wheel drive
260,000 MILES • V8 • 4WD • AUTOMATIC
RICM
I have replaced both motors for the four wheel drive system. With all wheels off the ground, all wheels will spin. When I have all wheels on the ground the front wheels do not work. All lights flash when I press the buttons and then stay on as if all systems are working.
What direction should I be looking?
Thanks
Ric Miller
Jul 19, 2009 at 9:50 AM
BRIAN 1
  • 1,030 POSTS
Turn the ignition ON, with the engine OFF.
Install a scan tool.
Use the scan tool in order to read the Front Axle Switch Status.
Does the scan tool display the Front Axle Switch status as Locked?
Go to Step 4
Go to Step 3
3
Use the scan tool in order to read the Commanded Mode Indicator status.
Is the transfer case in Auto 4WD, 4WD HI, 4WD Low mode?
Go to Front Axle Will Not Engage
Go to Step 5
4
Use the scan tool in order to read the Encoder Gear Position status.
Is the transfer case in 2WD mode?
Go to Front Axle Will Not Disengage
Go to Step 5
5
Replace the transfer case shift control module. Refer to the Transfer Case Shift Control Module Replacement .
Is the repair complete?
Go to Step 6
6
Use the scan tool in order to clear the DTCs .
before you do anything I would have it scanned for any transfer case codes,then post the code. also the 4WD mode switch was a common problem on these. but I would start with the above first.
Jul 20, 2009 at 11:22 AM
