What does this fuse go to? why does it blow continuously?
Dec 14, 2008 at 3:22 PM
BLUELIGHTNIN6
✓Experienced Mechanic
Your ECM or Electronic Controle Module is vital for your vehicle's engine to receive spark. I suggest checking the grounds on the ECM. If these are good, run a test light across the fuse terminals and wiggle the wires in that circut. Iit lightsup bright that means youave a chaffed wire thats groundin intermintantly.
Also check for voltage at plug wires. If one is lower than it should be, suspect faulty ignition coil.
