how to drain torque converter when I change fluid and filter?
Dec 13, 2008 at 5:19 AM
BRIAN 1
✓Experienced Mechanic
you can't drain the torque converter unless you remove the trans and remove the torque converter. the best way is to have a transmission flush, by a trans flush machine it will get all the dirty fluid out. you can get this service done at most service stations and the dealer.
