1999 GMC Sierra starting
1999 GMC SIERRA
160,000 MILES • V8 • 2WD • AUTOMATIC
LEVIASPREY
My truck will not start on the first attempt no matter how long i hold the key. it does not matter if it is hot or cold. it takes 3 tries every time. Now the back story. On a cold engine it would not start so my mechanic said fuel pump. I replaced that and nothing. Next he did a pressure test and determined it was the pressure regulator. I fixed it with that. I then took my truck to a friend who worked at a dealership and he put a super awsome fix all system cleaner. not so awsome. the problem came back only worse. it does not seem to be getting more worse and it has been a long time. any body that looks at my truck says there is nothing wrong with it. any thoughts.
Jul 1, 2010 at 3:30 PM
If the fuel pressure is within specs and the fuel pump relay tests good-check and test the coolant temperature sensor this is the one that gives you fuel during initial start ups-also might want to test the fuel pump and oil pressure sending unit-
Jul 1, 2010 at 4:57 PM
