When appylying brakes at any time when moving it kinda shakes, or pulsates like the antilock is kickin in. What do I do?
Oct 27, 2008 at 3:43 PM
✓Experienced Mechanic
Hi there,
if this is a pulsation in the brake pedal, get the rotors machined, as one or more will be warped, just make sure that they check the thickness first as there is a min safe thickness that should not be exceeded.
Mark (mhpautos)
Oct 27, 2008 at 3:49 PM
ZIBBYDS
MEMBER
1 POST
I pulled the tires off and the front(outside) of rotor is smooth and the inside is a bit grooved. It was fine until we parked it and drove it minimal. Think sitting woudl cause them to warp, the pads have at least 3/4 left on them for sure.
Oct 27, 2008 at 3:59 PM
You will not see this warpage we are talking about thousandths of an inch, .040"- .060" run out is enough to give you this pulsation, i would get it check out.
Mark (mhpautos)
Oct 27, 2008 at 4:08 PM
