1999 GMC Sierra knocking sound in engine
1999 GMC SIERRA
135,000 MILES • V8 • 4WD • AUTOMATIC
METZA1
Most of the time (probably about 80% of the time) when I accelerate from a dead stop, I get a rapid knocking sound from under the hood. It also makes the noise continuously if I’m parked facing up a steep hill. If I rev the engin while not in gear, the is no noise.
May 20, 2009 at 2:06 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:defe54523a="metza1"]Noises problem
1999 GMC Sierra V8 Four Wheel Drive Automatic 135000 miles
Most of the time (probably about 80% of the time) when I accelerate from a dead stop, I get a rapid knocking sound from under the hood. It also makes the noise continuously if I’m parked facing up a steep hill. If I rev the engin while not in gear, the is no noise.[/quote:defe54523a]
When did this start?
A couple possibilities.....
Spark Knock - Try Higher Octane Fuel
Timing needs attention - Check timing,
Also when was last tune up Cap, Rotor, Plugs and Wires.
And if haven't had timing chain changed it is probably time.
Another possibility is a weak Oil Pump, check oil pressure.
May 20, 2009 at 2:26 PM
DR LOOT
  • 2,311 POSTS
It does not sound like the engine to me, it sounds like you have drivetrain problems, first of all get underneath your truck and check all of your U-joints to start with.
May 20, 2009 at 3:23 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:8ed7e51687="Dr Loot"]It does not sound like the engine to me, it sounds like you have drivetrain problems, first of all get underneath your truck and check all of your U-joints to start with.[/quote:8ed7e51687]
I would almost agree Dr Loot if it wasn't stated that "[color=red:8ed7e51687]It also makes the noise continuously if I’m parked facing up a steep hill[/color:8ed7e51687]." How would it be making the knocking if standing still.
However, more detailed info on the problem would help out a lot.
May 21, 2009 at 3:53 AM
DR LOOT
  • 2,311 POSTS
I believe your truck has an anti-knock sensor on the right side of the block by the starter, it is round about 2 1/2 inches in diameter, with one wire going to it, it's supposed to work under load only!!!, so get on Mitchell 1 and find out how to diagnose it....I got on Mitchell 1 but I cannot find anything on the anti-knock sensor can you check and see if you have one on your truck? and get back to me.
May 21, 2009 at 5:51 AM
OBXAUTOMEDIC
  • 3,711 POSTS
The Knock Sensors are located in valley under Intake Manifold... This is the location for both 1500 & 2500 series and all V8's....
https://images.2carpros.com/forum/automotive_pictures/188069_99gmcsierra1500knocksensors_2.jpg
Here is Test Proceedure....
https://images.2carpros.com/forum/automotive_pictures/188069_99gmcsierra1500knocksensorstest_2.jpg
May 21, 2009 at 7:33 AM
DR LOOT
  • 2,311 POSTS
O.K. you don't have to kick my A$$ I'm just trying to help................ it must not be a knocking sound it has to be a backfire? the only other thing it can be is the cam or a bad lifter or a valve, sorry Loot Bug, it's like the blind leading the blind, if I could hear the noise, maybe I could come up with something, if I can help let me know.
May 21, 2009 at 3:51 PM
