1999 GMC Sierra fuel pump
177,859 MILES • V8 • 4WD • AUTOMATIC
CATEYESFULFER
replaced fuel filter and fuel pump and still won't start
May 31, 2008 at 1:33 PM
MERLIN2021
  • 17,250 POSTS
tart with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
May 31, 2008 at 1:36 PM
