is it possible to boost my performance by turning the fuel injectors up higher if so how would i do this
Feb 18, 2010 at 9:17 AM
✓Experienced Mechanic
Want a lil horsepower -all you have to do is get a 10K ohms resistor from an electronic shop and disconnect the coolant temperature sensor and hook it up on the wiring connector in place-This will fool the computer that the engine is still cold and give more fuel-
