1999 GMC Sierra Cold air goes to hot
150,000 MILES • V8 • 4WD • AUTOMATIC
JARRED318
Truck a/c system will blow cold air sometimes usually for about 20 mins. then will start blowing hot if you cut the a/c off for about 20 mins. it willl blow cold again mechanic before me supposedly changed an orfice tube filter and the compressor I have had the system down when i replaced the heater core in the dash and had to break the evaporator out vaccumed it down and recharged to correct charge
Aug 12, 2010 at 2:45 PM
  • 75,988 POSTS
Hi Jarred318, Welcome to 2carpros and Ty for the donation
Your probable causes here could be one of the following whether its manual or auto AC system-Could be the orfice tube but you take care of that, low pressure cut switch, clutch relay, the clutch itself, defective temperature sensor and the HVAC control module
Aug 12, 2010 at 6:03 PM
