1999 GMC Sierra Brakes Vibrate
1999 GMC SIERRA
80,000 MILES • V8 • 2WD • AUTOMATIC
DCRUZE
I have a problem with my brake that when you push the peddle halfway to the floor they vibrate like the anit-lock is trying to kick in. I changed out the master cylinder and while bleeding the lines found out that my rear calipers were sticking so I replaced both rear calipers, I still have the problem.
Can it be from air in the lines or is there something else going on?
Nov 4, 2009 at 11:01 AM
  • 31,937 POSTS
Hi there,
Have the rotors checked for excessive run out, warped rotors are very common, start here'
Mark (mhpautos)
Nov 4, 2009 at 11:21 AM
