1999 GMC Sierra
AKBUSHPILOT2006
  • 1999 GMC SIERRA
  • V8
  • 4WD
  • 170,000 MILES
I replaced brake pads and rotors and spark plugs and wires on my 99 gmc sierra. Before I replaced these items everything worked fine now The truck runs ruff and the four wheel drive will not work. I checked all the fuses. I double checked to make sure the right plugs were installed. Everything seems good cant imagine what I did wrong.
Sunday, January 31st, 2010 AT 8:23 PM
PEAR69
  • 1,482 POSTS
What brand plugs and wires did you use? Does your engine have a distributer? If so then did you replace the dist. Cap and rotor? If the engine has coil packs, did you have the coil packs tested?
Monday, February 1st, 2010 AT 6:30 AM
