1998 GMC Sierra ????????stalling
100,000 MILES • V8 • 2WD • AUTOMATIC
YBOTJAY
relpaced waterpump
replaced belt
thermastat
and + battery cable after roadside water pump failure
after all done started truck and was waiting to fill system after thermastat opens the truck stalled. I tried many times it finaly started I wondered if it was because i changed + cable. so i filled system and took for a test drive it ran good til it shifted to the next gear and it shut off and on a couple of time and i got it home. i checked for any thing off or unplugged but all checked out. so i started it the next day to take the truck to a friends garage to hook it to the scanner and it said crank sensor so i changed it. nope it still shuts off and on between shifts and well cruising. some people say fuel pump and some say ignition switch.im thinking the truck ran flawless before water pump went what could it be?thanks for any help Jay
Aug 26, 2009 at 5:48 AM
DOCFIXIT
  • 18,828 POSTS
Check two grounds one on right cylinder head and one on right front engine. Also check small red wire comming off batt pos.
Aug 26, 2009 at 6:21 AM
