1998 GMC Sierra R.P.M.
MRFIXIT951
Engine Performance problem
1998 GMC Sierra V8 Four Wheel Drive Automatic
in park, everything is fine, in drive when i come to a light to stop the engine raises and lowers the rpm and makes the truck kinda lung and in reverse it does the same, but if i put it in neutral, the rpm is normal.
Jul 30, 2008 at 1:39 PM
BLACKOP555
  • 10,386 POSTS
sounds like a fault with the IAC module not increasing the idle when put in gear to prevent this.
could also be a bad neutral drive sensor.
Jul 30, 2008 at 3:21 PM
